wildchev67
- Joined
- Jan 7, 2024
- Posts
- 6
- Reaction score
- 5
I just did this swap on a 2011 escalade platinum, with MaxTrac 2" drop spindles.
The brakes all fit, but the wheels did not. As far as I can tell, I am running the same Platinum wheels, as the first post.
-Does anybody know if the 2012 platinum wheels have more clearance for brakes?
Currently running longer wheel studs and a 1/2" spacer, but would like a better solution. Likely 2021+ GM 22" wheels in the future.
For caliper spacing I used a couple shims, 0.133" total thickness. This almost centered the caliper, with just a little more space on the spindle side.
If using drop spindles, I had to cut off one stud on bottom of the backing plate.
Parts list:
Parts list:
GM GENUINE | 84793057 | Caliper (Drivers Side) |
GM GENUINE | 84793058 | Caliper (Passenger Side) |
GM GENUINE | 11569590 | Banjo Bolt x2 |
GM GENUINE | 21012386 | Banjo Bolt Washer x4 |
GM GENUINE | 11546469 | Caliper Bolt x4 |
GM GENUINE | 84495310 (84763236) | Brake Backing Plate (passenger side) |
GM GENUINE | 84495309 (84763235) | Brake Backing Plate (Drivers side) |
POWER STOP | AR82209XPR | Rotors (both sides) |
POWER STOP | Z37-2407 | Brake Pad (both sides, pins included) |
