blackelky
- Joined
- Oct 15, 2023
- Posts
- 528
- Reaction score
- 650
Ordered GM charcoal canister, purge valve and gas cap replacing parts this weekend.
don't forget the one under the hoodOrdered GM charcoal canister, purge valve and gas cap replacing parts this weekend.
I always get them confused unless I go look it up..... lolThe one under the hood IS the purge. Vent valve is in the back.
I did not. Have seen some knock retard in the past, upto maybe 5 degrees. Just found a log where it was 0.6 degrees pulled..
40% throttle, 2400 rpms in 1st, 35kpa.. not really in the change portion. (.6 was probably interpolated from neighboring cells)
Maybe when the weather warms up.
These are the actual values, gray areas are the updated areas that have be reduced from pre 2013 tunes.
Shouldn't matter unless you are getting that much timing pulled.
So that probably wasn't worth the programming cycle..
