Intro - First Offical Post (Recent replaced 98 Yukon with a 17)
RobH
San Antonio
The original issue transmission thermal bypass valve (thermostat) for the MYC (6l80E) and MYD (6L90E) transmissions maintains the transmission fluid at around 185F. The Service Bulletin No.: 21-NA-199 (search online for the current version) calls for installing a 70C/158F Thermal Bypass Valve to keep the transmission cooler. You may not have one of these two six speed transmissions.
RobH
San Antonio
Further to my last, there should be a SERVICE PARTS IDENTIFICATION (SPID) stickerSPID.jpg on your glove box door. It lists the three character codes for Factory installed equipment. The code for the 6L80E transmission is MYC.
6 speeds
L Longitudinal/RWD orientation
80 - power handling rating
E - controlled by Electronic Control Module.
You can take your VIN to a GM dealership parts counter and get a listing of what all the three character codes mean.
Thank you for your service. Rob H
Jamesj82
