Bad o2 or bad cat?
j91z28d1
can't tell from the pics. if it possible to take it apart and inspect the cats visually?
but yes, a plugged up exhaust can cause spark knock.
C
crownvic31
Guys I am at lost here.
Its been a few weeks since I updated but I have no other solutions.
So truck is still doing the same. Ive replaced coils and fuel injectors and yes OEM and pretty expensive. Also replaced rear o2 sensors OEM. All cylinder misfiring, low engine performance, loud vacuum on the driver side rear around the valve cover and exhaust smells some what like burnt gas.
truck parked, 2500RPM STFT are switching between -10 and +10. LTFT are steady at +9.
while I was parked and rpms at 2500 I noticed that both cats were reaching high temps pretty fast. Bank 2 made it to 1043 and bank 1 to 1020. this was holding the rpms at 2500 for about 15 seconds.
C
crownvic31
Also,
Ive done several smoke test as well as my mechanic shop and I have zero leak. Can it be possible that my cats are bad causing some kind of back pressure? This is so hard to diagnose.
blondie70
Senior Member
You could pull out the front O2 sensor and run it to see if it runs better....quick way to reduce back press. Good Luck
C
crownvic31
Ok so this is a reading of the o2s. 1st one and 3rd are front o2s. 2nd and last are rear. This is running. Those rear o2 sensors have to much activity i believe.
Can anyone verify this?
C
crownvic31
So i did a on board monitor and this showed up. Im guessing that thisnis a bad cat?
jonnybalo
