Public Service Message - AFTERMARKT O2 sensors SUCK!
2006Tahoe2WD
Silicon Valley
Also, why does it say programming required on many purchase sites?
I'm planning to disconnect the battery and change them. The ECU should pick them up and deal with it from there. Right?
donjetman
in April of 2022, at 174k miles on our 07 Denali w/6.2L,
I did not disconnect the battery,
I did not need to do a relearn,
I changed all four O2 sensors w/two Genuine GM# 213-3533 - $58ea, & two Genuine GM# 213-3538, $53ea; all from amazon.
I've put 19k miles on them without issue.
MN-cj
Last October, on my 2014 Suburban with about 220k miles on it I replaced all 4 original O2 Sensors. They had started throwing codes so I had been running Costco's 92 octane gas with additives which kept the codes to only be occasional during MN winter and not during the summer. I put in two GM genuine ACDelco 213-3866 (GM 12583804) and two GM genuine ACDelco 213-4229 (GM 12609457). Like previously stated by another, I also did not disconnect the battery or need to do any learn procedure. It is about 7k miles later and gas mileage has increased and not a check engine light to be seen for my O2 sensors anymore.
DOC1583
