2008 tahoe 5.3l in need of desperate help
Nickct203
My wife has a 08 tahoe 5.3l, I put this engine a little over a year ago. She had an oil change done and the guys got pissed cause she refused to spend $190 on an oil flush and only put 2.5qts in and not the 6qts she needed. So needless to say the freaking blew the lifters to hell and back. I didn't have time to do the engine work so a very good friend of mine is doing it. He tore it down cleaned and checked everything. Put all new parts in it and finally was able to start it tonight and now it is suffering from a cylinder 1 and 2 misfire. He's been at it for 8 hours and can not figure out what's causing the misfire. Can anyone please help me. I had to drop my rental off so now we are down to 1 vehicle and that just won't work. Please someone help me out.
Charles Hughes
Has your buddy tried to swap cylinders 1 And 2 coil packs with another cylinder and see if the misfire switches? Eliminate a bad coil pack and spark plug first
If there was either a different crank or cam sensor installed, then a CASE relearn is in order.
N
Nickct203
New wires and plugs. Coil packs only had about 10k on them, but still moved them around just to be sure.
petethepug
Michael
SoCal
The end is where the simplest mistakes are made. I thought about switching the coil pack too.
Next come swapping the plugs or wires or what Fless said.
N
Nickct203
New crank and cam sensor with new cam. He said he did the tune for the engine to accept the new parts.
N
Nickct203
New plugs and wires. The rest of the cylinders are good just 1 and 2. Doesn't matter what *** swapped around the rest still ran good
You could have two bad plugs -- it wouldn't be the first time. Pull, check for carbon tracking or cracked porcelain, and swap them to good cylinders.
sylentnite
