claustralia
- Joined
- Nov 14, 2023
- Posts
- 17
- Reaction score
- 23
Hey everyone, been a lurking for a while, figured I'd post my recent Yukon buy and work I've done so far. 07 5.3 SLT with 300k miles :O. It had a new engine dropped in around 250k and I had the transmission rebuilt due to slipping after my purchase. Mainly my kid carrier but would like to make it last as long as possible. I've had an 01 Sierra for the last 20 years, which I kept, but figured I'd try my luck on the GMT900s (wife likes the body style more). Needless to say, I've done quite a bit to revive it and kept track of every purchase. Here is the long list:
The last thing I'm struggling with is my rack and pinion. I still get inconsistent return to center steering and after having replaced the entire front end and two alignments, I'm assuming that is the culprit. I've read mixed reviews on rebuilt units and was curious what everyone's current thoughts are on those. Happy to open another thread for that. It has been a great learning experience!
Here's a pic pre front suspension re-build, it sits much higher in the front now:
Rebuilt Transmission | ||
VXDIAG VCX Nano GDS2 and Tech2Win | Amazon | Scanner Tool |
GM GENUINE 15881861 | RockAuto | Buzzing Sound Rear A/C Control |
DORMAN 25828 | RockAuto | Broken window Scraper Seal |
STABILUS 3B807349 | RockAuto | Liftgate Lift; Right |
STABILUS 3B242389 | RockAuto | Liftgate Lift; Left |
STABILUS 4B047123 | RockAuto | Back Glass Lift; Left |
STABILUS 4B045928 | RockAuto | Back Glass Lift; Right |
ACDELCO CF193C GM Original Equipment; Carbon Cabin Air Filter | RockAuto | Cabin Air Filter Replace |
ACDELCO 1581644 | RockAuto | Blower Motor |
Edelmann 80617 | Amazon | Power Steering High Pressure Hose |
EDELMANN 80702 | RockAuto | Power Steering Low Pressure hose cooler to reservoir |
EDELMANN 80618 | RockAuto | Power Steering Low Pressure hose gear to cooler |
DORMAN 924716 | RockAuto | Ignition Lock Cylinder |
SHEE-MAR SM1520 | RockAuto | Front Right Latch and Actuator Assembly |
SKP SK931303 | RockAuto | Front Left Latch and Actuator Assembly |
SKP SK931108 | RockAuto | Rear Left Latch and Actuator Assembly |
SKP SK931109 | RockAuto | Rear Right Latch and Actuator Assembly |
GM GENUINE 22834330 | RockAuto | Cabin Air Temp Sensor Front/Rear |
GM GENUINE 15947841 | RockAuto | DIC Display Buttons |
SKP SK901159 | RockAuto | Liftgate Window Release Button |
GM GENUINE 20983936 (x2) | RockAuto | 12v Outlet Cover |
GM GENUINE 84356647 | RockAuto | Front ABS Wheel Speed Sensor |
TRICO 13220 Ultra; Beam Style | RockAuto | Front Wipers x2 |
ACDELCO 25820122 GM Original Equipment | RockAuto | Rear Wiper |
Door Locking Rod Knob - GM (15844617) | GM Parts Direct | 4x Door Lock Knobs |
Driver Side Front Door Weatherstrip - GM (22766409) | GM Parts Direct | Replace Driver Side Door Seal |
2020 Style GM Key Fob Retrofit | BoostAutoParts | Replace Key Fob |
Amsoil Power Steering | Amsoil | 16 oz x 8 (4 qts) for flush/bleed |
Gruven Folding Mirror Assembly | Gruven | Fix side mirror gears |
GM GENUINE 15798935 | RockAuto | Rear Wiper End Cap |
Battery Terminal Tightener | Amazon | Battery Terminal |
ACDelco GM Original Equipment 22759208 | Amazon | Cabin Air Filter Conversion |
DORMAN 911064 | RockAuto | Vapor Canister Vent Valve / Solenoid |
GM GENUINE 215464 | RockAuto | Vapor Canister |
PRECISION DWB111007 | RockAuto | Rear Door Weatherstrip Seal |
Dorman 959-003 | Amazon | Driver Side Door Mirror Cover, Chrome |
Exterior Chrome Door Handle Rear Right Passenger Side | Amazon | Exterior Chrome Door Handle Rear Right Passenger Side |
GM GENUINE 13498958 | RockAuto | Headlamp Light Sensor |
GM GENUINE 84370714 | RockAuto | Upper Intermediate Steering Shaft |
Front Driver Exterior Door Handle Replacement | Amazon | Front Driver Exterior Door Handle Replacement |
SYLVANIA - Headlight Restoration Kit | Amazon | Headlight Restore |
GM Genuine Parts 25815601 | Amazon | Steering Shaft Boot Seal |
ACDelco GM Original Equipment 214-1680 | Amazon | EVAP Purge Valve |
ACDelco GM Original Equipment GT295 | Amazon | Fuel Tank Filler Cap |
Denali Grille Denali Upper OEM | Ebay | Denali Grille Denali Upper OEM |
LEFT QUARTER PANEL HATCH GATE TRIM APPLIQUE OEM | Ebay | LEFT QUARTER PANEL APPLIQUE OEM |
19121538 Seat Belt Buckle End | Ebay | 19121538 Seat Belt Buckle End |
15816854 VALVE,BK BODY OPG FRM PRESS RLF | GM Parts Giant | Rear Cabin Pressure Vents x2 |
DiabloSport 8245 inTune I3 Platinum Programmer 01-10 6.6L GM Duramax | JB Tools | Diablo Sport Tuner |
Diablew Tune | Diablew | Custom Tune |
J-42640 | Freedom Racing | Steering Column Lock |
Third Row Seats | Craigslist | Third Row Seats |
Seat Covers | Ebay | Seat Covers |
Seat Foam | Seat Shop | Seat Foarm |
Left Air Vent | Ebay | Left Air Vent |
ACDelco GM Original Equipment A3181C | Amazon | Air Filter |
Top Air Vent Cover | Amazon | Dorman 926-336 |
GM GENUINE 19178561 | RockAuto | 2x Inner Tie Rod |
MEVOTECH TXMS506116 | RockAuto | 2x Outer Tie Rod |
MEVOTECH CTXK80669 | RockAuto | Front Left Upper Control Arm |
MEVOTECH CTXK80670 | RockAuto | Front Right Upper Control Arm |
MEVOTECH CTXMS50152 | RockAuto | Front Left Lower Control Arm |
MEVOTECH CTXMS50153 | RockAuto | Front Right Lower Control Arm |
MEVOTECH TXMS50820 | RockAuto | Sway Bar Link |
MONROE 139104 x2 | RockAuto | Front Shock/Strut Coil Assembly |
GM GENUINE 15124516 x2 | RockAuto | Sway Bar Bushings |
Replacement Gears for Seat TIlt | TwoMen1Garage | Replacement Gears for Seat TIlt |
MEVOTECH H515097 | RockAuto | 2 x Front Whell Hub Bearing Assembly |
WAGNER OEX1092 | RockAuto | Front Brake Pads |
RAYBESTOS 580279FZN | Amazon | Front Brake Rotors |
Raybestos FRC11713N | Amazon | Front Right Caliper |
Raybestos FRC11714N | Amazon | Front Left Caliper |
GM Genuine Parts 176-2003 | Amazon | Front passenger brake hose |
GM Genuine Parts 176-2002 | Amazon | Front Driver brake hose |
GM Genuine Parts D1539J | Amazon | Brake Pedal Switch for Cruise Control |
WAGNER OEX1194 | RockAuto | Rear Brake Pads |
GM GENUINE 19420043 | RockAuto | Lower Intermediate Steering Shaft |
