1997 GMC Yukon Build Thread
97YukonNZ
97YukonNZ
Looking good. Now maybe you can rent out that tool to recover some funds.
You know,I had the very same thought in mind!
It will get used again when I rebush the front end.
Cant believe how easy it was to change those keys out!
Lol 1st check and I had it wound down 4"s!!
2 on the key and 2 on adjustment.
She was rubbing in the front badly!
Pretty happy at the moment.
Great to start getting her how I want hèr
97YukonNZ
97YukonNZ
17071807342177030211905767061320.jpgHere we are. Just pulled her out of the cave.
Bit of a rake but okay for now as is empty of petrol and no load in the rear.
Keep in mind I am going to refit stock body mounts as currently on 2" lift and am going to drop 2" by changing from 285 x 75 x 16 to 265 x 70 x 16 tyre. After that I will revisit the rake and maybe get the leaves leveled. 17071814482367820906536542660995.jpg
Will probably unbolt rear jounce stops and fix a new stop to the frame.
Very happy with this small change.
Gonna go for a roll and get some air in that rear tyre. Has a leak. :driver:
97YukonNZ
97YukonNZ
20240208_182141.jpgAnd check her out!! Just picked her up from the tyre shop. What a change! Both in look and drive. Is 5"s lower now but kinda looks the same with the lower profile tyre. Loving it!!!
97YukonNZ
97YukonNZ
A buddy has had my front air dam for a couple of months since a 4x4 trip that I broke and cracked it.20240209_153144.jpgHe does a bit of plastic welding and offered to fix it for me. 20240209_153314.jpgJust finished giving it a sand and threw some paint at it.20240209_155751.jpgIs a quick dry paint so will let be for a while and then I'll get it back in place.
97YukonNZ
97YukonNZ
Looking great man!! Good work.
Hi Sam!
Thanks man!
Lol it has been a long time thinking about changing the Suspension and things on her.
I was going to go for a blackout look with new wheels.20231119_182516.jpgYhis was going to be my wheel choice.
$830 each and 2 months by sea to get here from your country.
After a lot of thought I realized that what I was really needing was the 2" drop that the 20" performance tyre would allow so I could lower the Suspension a couple of inches.
I came to the conclusion that all I needed to do was find the right tyre for what I had and i could keep the Mickey's on there.
They are pretty tuff and i dont want to lose them. :D
brittyboop0510
