2000 Yukon XL Reprogramming Climate Control
Chet70
Hello Everyone!
I am new to this forum and am wanting to get some info on how to reset my climate control system in my truck. I had the battery disconnected for about 5 days while I replaced the intake gaskets and when I reconnected the battery, the system stays on defrost. Blower and auto works fine, just no adjustment on the floor/defrost/vents.
Any ideas?
Thanks!
Hello Everyone!
Any ideas?
Thanks!
disconnect battery again or pull hvac fuse, wait a few seconds, reconnect.
that should make it recalibrate
C
Chet70
So I tried that a few times and it still didn’t work. Couldn’t hear anything happening under the dash either. Any other ideas?
leave the battery disconnected or fuse out for about 5 minutes and try again, that should work. If not then either the actuator is stuck or you need a tech2
NELLY1947
Also I've been told to connect the positive first then rhe negative I've been told that way no arching.
The trick is to do in one shot and not be wiggling it around so it's intermittently loosing connection while tightening, this can cause a bad handshake
C
Chet70
What do you mean by a tech2?
Fless
Super Moderator
Elev 5,280
BLUK0N
