The pics will show the damaged harness connectors. Male and female ends of both the upper and lower harnesses with the grey bale locks. I am also supplying the pic of the way they look when not chewed up. This is on the 2001 C3500 Silverado dually crew cab long bed that because of this harness problem and an as yet to be determined coolant leak, may end up with me for $2k. Anyway, I found what I believe to be are the right harnesses at ebay but will buy here if it is a match. The LB7 was done 2001 to 2004, I believe and the harness for the 2001 and 2002 are the same. Thanks if can help. Contact me here and tell me the price if found and we can work it all out. Thanks.
