2003 Chevy Tahoe Performance Chip Recommendations
Dantheman-2003
Placerville, Ca
Again I say, I know opinion vary in terms of performance chips and tunes. That said, based on my own research, I’m leaning towards a simple performance chip to get a little more boost in my 03 Tahoe. Ideally looking for a plug and play product that’s been tested by someone in the Tahoe/Yukon club. Any thoughts, considerations or recommendations would be appreciated!
Thanks,
Dan
Thanks,
Dan
I don't believe there are any "chips" for these things. For the most part, "chips" went away before OBDII started, almost thirty years ago. Ever since, PCMs/ECMs are simply reprogrammed with a program on a PC/laptop or a handheld tuner.
As the others have said, the best bang-for-the-buck is an honest tune by an experienced tuner. Most of the gains will be from utilizing the power your engine already produces by getting it past the transmission. Your first step is to ensure your engine is completely up to par in stock form with good spark plugs, no vacuum leaks, good/normal fuel supply, etc. If you don't have it, switching to an electric fan would yield a notable gain. If you use a stock setup that is controlled by the PCM, a tune will be needed to activate the fan's programming. So you can have it all knocked out in one shot.
drdave81
Waterford, MI
Another vote for an actual tune. Especially when you look at the cost to gains. You're dropping $300-500 for a plug n play diablo or similar, and a full on PCM tune will cost right in that same range with far more gains than anything you'll ever plug in under dash.
03catburban
Georgia
The hand held programmers are junk they hardly do anything for the money you pay.
I do tuning myself so speaking from experience and a custom tune will free up the most power, mainly from adjusting the torque management.
Also electric fans fans will make a difference and you'll need a actual tune to turn them on
RAMurphy
Bob
S. Maryland
And another vote for an actual tune. Years ago I did a significant amount of research on this and went with a custom tune. I already coverted to electric fans - and that did make a small difference. Prior to the tune I was using a "probe" to turn on the fans as required. With my tune they made the change to turn on that feature so the computer operated the electric fan. As others have already stated ensure your engine is up to spec (spark plugs, spark plug wires, no vacuum leaks, etc.). I personally went with Black Bear Performance for my tune and I'm quite pleased. But there are other ways to get that accomplished,
BlackBearPerf
Supporting Vendor
Coeur d' Alene, Idaho
Thanks,
Dan
Lots of good info here! We have a few ways to tune your Tahoe. The difference with custom tuning compared to getting a canned tune and such is the tuners experience and seeing vehicle data before we tune.
I think the shifting improvements, and throttle response improvements are the changes that you can really feel with the tune. Some HP TQ gains are there but you may not feel it as much as the other improvements. The tune makes the vehicle more responsive, improves drivability. All of this is depending on fuel quality, octane, and condition of the vehicle prior to the tune as well. We can enable electronic fan control, and much more.
SWoolf777
