2007 Tahoe/New member from sunny California/Looking for some advice
C
Caligirl
California
Sounds like a great deal!
Yes, '09+ has the 6-speed. I believe the exception is the PPV got it in 2010+. Factory Bluetooth isn't all that special. It's for phone calls only. My personal recommendation is to get an aftermarket HU and you'll have tons more features, phone and music streaming via Bluetooth (or Wi-Fi if you get a fancy enough HU) and better sound. Other than the better trans, about the only real mechanical issues that were improved upon was the AFM components and the driver's side rocker cover.
The gas cap may have been replaced with a non-FF OEM or aftermarket. I believe the only difference is the color. The only way to tell if it's FF by looking at the engine is to ID the injectors. You can double-check your build specs by looking at the RPO label on the inside of the glove box lid. Look for "LMG".
Your '07 came with the "first and worst" iteration of AFM. There's a chance the parts were updated, though. They improved the VLOM and lifter designs to greatly increase reliability. Since yours is low-mileage, you're in a great position to disable it and let it ride. My personal recommendation is to have it tuned out. You can get someone local to do this and it'd likely be at least $150, which is still cheaper than the plug-in module options. Or, you can send the PCM to this guy and have it done for about $70 or less, depending on shipping. If you wanna splurge, get a full custom tune by someone who specializes in these (such as Black Bear) and you'll get all kinds of improvements from better drivability from more responsive throttle and shifting characteristics to increased trans life. Above all, use quality oil and change it regularly, before it gets too nasty. My experience shows that 5,000 miles is a good OCI for when the oil starts to get dark. Use of a quality full synthetic oil and good filter is paramount.
As this is a common problem, you're suspicions may be correct. Nobody here knows your husband's mechanical aptitude. But, I'd rate replacing the door latch as a "3" on a 1-10 scale. Somewhere above an oil change but a under a brake job, if that tells you anything.
Batteries often show their faults when the weather changes, especially from warm to cold. Did it fail during a cold snap in your area? It may charge up and hold enough voltage to start and run it and seem "okay", but it could have an internal fault that the fancy electronic tester could see. Of course, there could be other possibilities. You can do a simple test with a DVOM (digital volt/ohm meter) to see if there's a steady drain and on what circuit. You set the meter up to read amps, disconnect the negative cable from the battery, put one of the meter's leads on the battery post and the other lead on the cable. Take note of the amps (should be milliamps). If they're high, remove one fuse at a time until the measured draw plummets. This will be the circuit that has the drain it. Be aware that, out of the many computers in this thing, some are still active long after the key is turned off and removed and the doors are shut. Some may reawaken from the disconnect and reconnecting of the battery, even if through the DVOM.
Could be tires, trans, front or rear differential, hubs, etc. Make sure it's not in 4WD (neither 4HI nor 4LO).
So once the modified ECM is installed after AFM removed, will the display that shows V8 vs V4 now ONLY show V8? Because if not, how do we know the modification was successful at keeping all 8 active?
89Suburban
Bull in the china shop
SE PA
Get the Range device and pull it out a few weeks before emissions inspection. When you go to update the valve cover what it looks like inside will tell you how well it was maintained. Hopefully it is nice and clean. Install a catch can.
89Suburban
SE PA
But...here you are reading the thread and commenting!
Seriously, though, lotsa' good advice and info I've received from all these knowledgeable, generous folks.
Yes very good people here, I read it every day, great place with lot's of help and great info. :)
Yes, it will show "V8 MODE" at all times. These engines only run in either V4 or V8 mode. They run in V8 mode as default and AFM, if activated, makes it run on four cylinders if all the parameters are met. Having the PCM tuned to disable it is just having AFM taken out of the programming. It's not being programmed any differently than a stock engine that was not equipped with AFM. They just simply turn the AFM controls "off". It can be reversed by having the PCM re-tuned to have AFM turned back "on".
C
Caligirl
California
Just got our ECM back yesterday. Hubby plugged it in and now running V8 :)
Now to do catch can AND another modification. Was looking for weaknesses re. prevention of rodent intrusion (vents and cab air filter mostly) and low and behold found out we need to add the cabin air filter door kit and filter to keep the dust under control. I'm sure this is an old topic for you all but WTF? These 4x4 trucks are designed to handle going places where there is dirt...*scratches head*
thompsoj22
Im pretty sure that the cabin filter was designed and placed into production for a few years but owners were not aware of the scheduled maint on the filter and in dusty environments the filters plugged, Reduced the airflow to the point of freezing the condensate to the evap core and fubar the ac system. So instead of calling out the retards they opted to punish all customers and delete the filter option. We installed the retrofit kit and it works great!
Heavychevyvito
