2010 Tahoe warning lights
WheelmanF5
2010 Tahoe 4WD LTZ with 7.5 lift & 35s the TPS warning lite is on to be serviced. I replaced all sensors the warning stayed on. Also the service suspension warning is on. Any ideas on clearing these?
Do you have a quality bi-directional scanner? You could use the scanner to find the source of the warning light.
You should check the wheel speed sensors, as a failure in one of these could trigger the warning lights.
Coolman1987us
Maine
You need to relearn the new sensors to the truck. They don't just work.
Also your service suspension message will never go away until your suspension is put back to factory. Just the way it is. You can clear it with the checkmark button for the dic every time you start the vehicle.
