2019 no crank nor start
chas442
First Post. Been lurking since 2019. I have a 2019 Tahoe LT. Love it as much as my previous 3 Suburbans. It has push button start, new battery changed 4 months ago. I try and start and dash lights come on briefly. 5 seconds of no dash lights everything comes on as if normal run sequence with the expected check engine light being illuminated. Gauges go thru their sweep and read as expected. Battery voltage 12.45v using a DVOM. Battery voltage does not vary during start attempts. Scan tools shows no DTCs.
Any and all help will be greatly appreciated.
NickTransmissions
Sin City
The transmission bench
Could be internal mode switch failure, especially if all your int accessories, radio and lights work. The IMS is in the transmission and communicates range position to the powertrain control module. Sometimes no codes will set/store if channel N (the IMS comm channel that sends the P/N position signal to the PCM upon key on).
Welcome to the Forum from NH.
Pics of the truck, please.
DB1337
