2023 Rearview Mirror Access
ATrainTX
I figured I might as well ask here before I destroy this piece of plastic on the mirror trim trying to get access. I have a new 2023 Yukon XL Denali with the live rearview mirror. Trying to remove the trim to access the power port for the Gen5DIY adapter I bought to mount a radar detector. Their video shows a different type of mirror trim and I cannot figure out how to pop off this trim to access the mirror power port for this harness.
Anyone have any tips for me? I do have a trim removal tool but not sure if I should be prying on the TOP or the bottom of the center insert piece.
zbad55
Detroit
Maybe stop by an auto glass shop, they will know how to do it for sure since it needs to come off in case of a windshield replace. I;m sure they would know any ticks to make it easier
ATrainTX
ATrainTX
This was good advice! I asked my window tint guy when he was working on that to take a look. For future searchers looking for this answer — you just need to push UP from the entire bottom housing towards the roof and it pops off to allow you to access the center insert piece that unclips and then you’ve got access.
suterusu
Just did this over the weekend for the same reason. I popped out the center piece and then slid the larger piece down.
navyseal334
Would love to see a picture of your mounted detector if willing.
ATrainTX
ATrainTX
Absolutely. I know that there are knock-offs out there but I have supported BlendMount for like a decade and it's just a great product so I'm OK with the higher price. Their mirror mount worked perfectly on my 23' with my Uniden R7 and the Gen5DIY power harness was seamless. Easiest detector install I've had on a vehicle to date. Big fan.
KMeloney
Bumping this, since no one has responded to my thread about instructions on how to remove this piece.
Posts #3 and #4 seem at odds with each other. Regardless, I don't understand the actual process used in either. Specifically, how can you push up on the entire housing if the top end is already against the headliner? Is there room to push it that directions? Or, are you pushing up and pulling away from the windshield at the same time? And as for removing the center piece, how do you do that? Do you have to pry it out with a tool? (if so, what do you use, and where do you start?)
And how does the housing mount to the windshield anyway? Are there tabs/rails stuck to the windshield that the housing slides onto?
If you guys could provide some more detail, I'd really appreciate it. Thanks in advance.
StephenPT
St. Helens, OR
Check out this video -
Link starts at him removing the cover on a GMC Sierra - later in the video around the 6min mark he removes one from an Escalade. Not sure if your Yukon has the wider cover like the Escalade, or not - but the process is essentially the same for both.
KMeloney
Sooooo helpful. Thank you!
From what he says after removing the Caddy one, it sounds like the Yukon/Tahoe one is just "wedges" in around the lip [of the stuff that's mounted to the windshield]...? Do I have that correct?
Thanks again.
dngerous
