96 Yukon Body mount bolt size
biggmac4
Anyone know what factory size body mount bolts are used on a 96 Yukon ? Anyone sell a kit with all the bolts? Factory mount height.
east302
Mississippi
Here is the parts diagram with bolt sizes and GM part numbers if you need them. In the third column, they list the model numbers. (06) is specific to a four door with (16) denoting the two door. 107 is a short wheelbase (Yukon) and 109 is long (Suburban). So 107(16) is a two door Yukon, 107(06) a four door. If it doesn’t differentiate (CK1,2,3) then the part works for all.
M12x1.75x110 for the body, x115 for the radiator supports. It doesn’t show the grade, but mine (1998, factory) are 10.9.
The rest of the diagrams are here:
biggmac4
biggmac4
much appreciated! Yes I have the 2 door 96 Yukon GT.
Here is the parts diagram with bolt sizes and GM part numbers if you need them. In the third column, they list the model numbers. (06) is specific to a four door with (16) denoting the two door. 107 is a short wheelbase (Yukon) and 109 is long (Suburban). So 107(16) is a two door Yukon, 107(06) a two door. If it doesn’t differentiate (CK1,2,3) then the part works for all.
A very complete answer to the OP's question. Thank you.
Another example on why this Forum ROCKS!
