After market gauges
Is there anyone who can point me in the right direction for a gauge install on my 93 tbi? I'd like to know what's needed for mechanical gauges (water temp and oil pressure) any help is greatly appreciated as I'd like to do this in the next couple days. (I tried a search and it came up with so much I couldn't go through it all) I'd like to retain stock gauges as well as have a aftermarket trio under the dash or some where similar.
This is what I'm wanting to get
https://m.summitracing.com/parts/sum-g2972
retorq
Kingman AZ
You have an open water temp hole in the passengers head that you can use. For the oil pressure feed you'll likely need to tee into the existing switch since you need to retain that.
sammyb
