Android Auto won't connect wirelessly
apex944
I have been using Android Auto with my new 2024 Denali via a USB cable because Android Auto via Bluetooth it does not work.
But... The phone IS paired via bluetooth, and I CAN make and receive calls without a USB connection.
However, I can not get Android Auto to connect to my phone via Bluetooth.
When I start Android Auto from the Nav Screen my phone recognizes that "Android Auto is Available"
But then when I select my phone (Pixel 7a) from the nav screen it spins and times out.
Any ideas on how I can resolve?
Phone:
Remember... Bluetooth IS WORKING between my phone and Yukon for calls.
Any help would be appreciated.
Phone:
remove the phone from bluetooth on the car radio
then remove the radio from the phone bluetooth
then simply plug in the usb cable, follow the directions to enable android auto
then unplug usb cable.
if it does not automatically switch to wireless at that point then restart the phone and vehicle.
upon restart just wait for it to automatically connect should take less than a 1 minute
and for reference wireless android auto does not use bluetooth alone it uses a combination of wifi+bluetooth.
apex944
apex944
Thx for this... I will try.
Have 800+ miles on the truck so far with no luck.
My previous truck had no WiFi and Android Auto worked with BlueTooth alone.
Did you mean that on the Yukon it was different? I wasn't planning on enabling WiFi in the truck.
it had to have had some form of wifi, just not the kind you could use as a hotspot and have to pay for, wireless android requires both wifi+bluetooth
that's just how it works.
it's called (wi-fi direct)
per google:
Wireless Android Auto works via a 5GHz Wi-Fi connection and requires both your car's head unit as well as your smartphone to support Wi-Fi Direct over the 5GHz frequency. While the connection happens over Wi-Fi, you will need an active data connection on your smartphone to access the internet on Android Auto.
the data bus on bluetooth just isn't enough alone to support wireless android
you do not have to turn on anything on the radio, just plug the usb cable in and follow the directions it gives. basically you are just allowing it access.
apex944
apex944
So I'm clear. Do you mean remove "My GMC" from phone's bluetooth ?
yes, after you remove it and remove the phone from the car radio,
then just plug in the usb cable and during the android auto setup it will put everything in correctly including the bluetooth.
that will give you wireless android and bluetooth will still operate like normal.
you will not have to do anything else besides any custom android settings that it allows you to adjust.
apex944
apex944
Followed your advice to the letter. No luck. I disconnected the USB and waited. The phone did not retain connection wirelessly.
I started looking at other menus and noticed this:
Neither my Android or my work iPhone are showing her. I assume that is what "no phones" means?
Also, should Android Auto be grayed out until I select it?
lady112210
