Automatic Foglights
gooffeyguy
St. Louis
Ok the group of 3 15a fuses in line are what you used. The first one. However my fuel pump relay is under it and I think the fog lamp relay is powering my trailer lights/tail lamp parks.
Also, concerning those 3 15a fuses, they all go to the parking lights. From left to right is trailer parking lights, left side parking lights, right side parking lights.
I tried all 3 when I installed mine and it doesn't matter which you use, just whichever is easiest and not blocking other fuses (although the add-a-circuit will still work if there's other fuses above/below where you install it, as it sits higher off the panel). It just makes it so you don't have to pull the add-a-fuse if you need to check/change the fuse it's blocking.
Turn on your parking lights then pull each fuse individually and watch each side light go out according to which fuse you pulled.
08z71bgm
Long Island, NY
Yeah I read that on the diagram after. Sounds right. The lower left relay lead with the bevel facing front of car is pin 30 and has constant power. That is why it’s powering the parking lamps with them off.
08z71bgm
Long Island, NY
Yeah I was dyslexic for a minute. Good to go now. Sorry and thanks for the help.
That wire is supposed to go to the bottom left pin on that relay. Look at the pic of mine in post #13, 5 posts before your pic. See the problem? You are running a constant +12v to your park lights.
TU1881
