Autoride not working
07warwagon
I have an 07 Suburban LTZ with the autoride, and have a 4" lift kit on it. Over the past couple months the air compressor doesn't turn on at all in the rear. Which sucks cause it was a big help when towing the sea doos or boat. Any suggestions on what the problem could be?
Modded
That Guy
Do you have shock extenders, seems like the install may have involved the peopple discnnecting the rear Autoride functions.
07warwagon
07warwagon
yes I do have shock extenders and the autoride was working fine until just recently
bocaytomas
your air compressor might have quit, or the fuse blown, check which fuse it is and then see if it was burned out, it could be a quick fix
BudLightyear
