B2610 Code - SOLVED
dps01
N. TEXAS
Just learning my way around a Tech2 clone that I finally ordered to assist with electrical gremlins on heated seat (still a work in progress).
While working my way thru the menus etc. I came across a Current DTC of B2610; Passenger Compartment Dimming 1 Circuit.
No indication of a problem on the instrument cluster or in operation of lighting except as indicated below..
Couple of questions:
1. On the Tech2 is there a way to determine when the code was set?
2. Can this be due to LED interior lighting upgrade? Trying to avoid re-lamping with incandescent to find out… but will if needed.
Recently installed LED interior lighting. The lights operate correctly when opening doors etc., but after operation of the vehicle for a while, the reading lamps will not come on unless you first use the lighted vanity mirror which still has incandescent bulbs. I assume that has something to do with the retained accessory power circuit? Or something else to do with the low resistance of the LED.
I can tell you that I do not get that code on my 07, and I have replaced all incandescent bulbs, inside and outside, with LEDs.
It could be related to the LEDs or it could be a functioning but bad bulb or a faulty BCM.
dps01
dps01
N. TEXAS
thanks. appreciate this.
the attachment gives me something to go on.
dps01
dps01
N. TEXAS
I believe that I may have found the issue… intermittent backlighting for the fog light switch. Replacement bulbs on order to affix to the circuit board… I am hopeful that is the issue.
Thanks for the assistance.
Aljaroudi
