BCM/whatever its called on chevy scanner?
rick1024
Fort Worth Texas
I am curious if there is anything like the FORSCAN on Fords for Chevy? Anyone know of anything like that? Id really love to kill the door chime and the 3 honk alert when you shut the door with the engine running to run inside for something. Really annoying.
RoadTrip
Saint Paul, MN & Tampa, FL
Under ‘Chime’ in the settings sub-menu, our 2015 has a selectable volume. It only goes down to ‘26’ for the minimum, but I should try it again using the volume control knob.
There is a setting to turn off the triple honk if you run inside while the engine is running. Ours is set to ‘off’, but sometimes it does it anyway unless I leave the fob in the console fob pocket.
Try these and see if you have any luck.
autosync is about all there is as far making changes
BlaineBug
You can disable the horn-honking alert for key left in vehicle from the infotainment screen.
BlaineBug
i did that, but my issue is when i leave the truck running and step outside the horn honks. i want to turn that off. i have the key in my pocket
It shouldn't, mine doesn't after I turned that setting off. However with the setting enabled, it used to honk when running.
RoadTrip
Here's what I discovered, in an attempt to stop the "Keyfob Not Found" message I kept getting when turning the vehicle off. My phone, charging on the center console armrest, was blocking the fob-to-receiver signal and the console sensor couldn't find the fob signal from my pocket, jus inches away. If I remove my phone from the center armrest charger BEFORE I shut off the rig, there's no problem.
I also had the triple "Keyfob Left In Vehicle" honk with the keyfob in my pocket problem but if I remove my phone from the armrest charger with the vehicle running and fob in my pocket, now I don't get the triple honk.
Hope this helps you.
texfoto
