Belt chirp…
draper11
Love this old thing. But this belt is maddening. In the past 12 months I have replaced water pump, alternator, belt, tensioner, and idler.
I wiped all pulleys clean, including filing down the tooling lines in the tensioner grooves.
Spraying soapy water or wd40 around idler pulley quiets it all down for a second.
Still can’t get rid of the chirp. Had a motor mount fail, not sure if that knocked my harmonic balancer out of alignment or what. My water pump pulley seems to have a wobble but not sure if that is due to undue tension somewhere else. I guess I will have to get the dealership to look at.
what year is it?
what about the ac belt? it either has a tensioner also or is stretch belt, if it is tensioner you can get the stretch belt and dump the tensioner which can be prone to making noise
donjetman
crankshaft pulley/balancers on these engines need replacing when they get old. They are 2 parts, inner and outer, held together by rubber that gets old.
pulley balancer < $100
seal <$10
bolt<$20
rent /borrow the removal & installation tools from the autoparts store
B-train
Does the water pump have a painted pulley, or clean metal finish where the belt rides? Seen tons of these in the generator world with noisy belts and I narrowed it down to paint on the pulley causing the belt to slip.
If that's the case, remove belt and emery cloth the pulley to bare metal where the belt rides and that will prevent slippage and noise.
If that's not the case, then I'd look at pulley alignment with a good straight edge to make sure it's not being pulled sideways on one pulley or another. Also, spin idler and tensioner pulleys by hand with the belt off and listen for noise.
D
draper11
seal <$10
bolt<$20
10-4. I will look at that next… Funny thing- I did pull out on the tensioner with the engine running and the squeal goes away. Perhaps there is not enough tension. Also, adding bar soap to groove side quiets it down completely.
D
draper11
The water pump edge is bare metal- but t
what year is it?
it is a 2011. I also changed out the ac belt two months ago. No tensioner on AC on this model.
D
draper11
Water pump pulley edge is bare metal. Definitely a lip where paint meets metal. I added tension to belt while running and squeal stops. Also rubbed soap on grooved side stops the noise.
j91z28d1
if it stops when you apply more tension to the tensioner and haven't replaced it. it's worth a try, or they sell manual ones for the race cars running high rpm that like to throw belts on shifts. could put one of those on it.
Jamesj82
