Broke 10mm bolt at shaft that holds brake light switch. Not much space to remove broken bolt. Any ideas?
AlbertoTahoe2011
Stripped 10mm bolt at shaft that holds brake light switch. Not much space to remove broken bolt. Any ideas?
That sucks. You may need to drill out the broken bolt, at least to the extent that it will break its seizure and come out. If necessary, you can buy a right angle drive attachment for your drill which may give you a better angle to access the broken bolt.
petethepug
Michael
SoCal
Call or look online to see who has a tig welder to weld or bond another bolt on to it.
I won’t climb in there anymore and can’t remember how much of the bolt area is susceptible to the momentary shot of tig heat.
jtidd
