Cammed 5.3l
mtbennett24
Anyone have a cammed 5.3l nnbs? Wondering if a cam mod is worth the $$$ and effort for a daily driver that does some boat towing too. Thanks!
JennaBear
Resident Ninja
Supporting Vendor
San Diego, CA
All depends on the cam you go with. Also, you might want to match it up with a stall, then you are opening a whole new can of worms!
M
mtbennett24
Hey Jenna, I found this on the GMFS forum. Are they talking about your Tahoe? Are these cams that might not require a stall and could still give low end power? They are referencing an '04 Z71 with 5.3l.
Biggest I'd go in your truck without a stall is a 212/218 on a 112 or 114LSA. However, since you're in a heavier truck, it may not provide the bottom end grunt that you want. In that case, I'd run a grind like JustinSS recently installed in his lady's tahoe. Something along the lines of 206-208 intake duration and 212-216 exhaust duration. I wouldn't worry about running an extremely high lift. Also, as far as lobe separation angle, 114LSA would provide you with a broader powerband and it would have somewhat of a lope at idle. 112LSA will have a more defined powerband and the idle will be a bit more lopier. That aspect is left up to you.
Suggestions without upgrading converters:
the COMP Cams 54-408-11. Its a 206/212 .515"/.522" on a 112LSA
If you think you may ever upgrade converters, I'd go with the COMP Cams 54-412-11.
JennaBear
Resident Ninja
Supporting Vendor
San Diego, CA
Yes, that would be mine. I didn't want to install a stall and I knew we would be running a blower. Was perfect with and withough F/I.
M
mtbennett24
Pardon the ignorance, but why wouldn't you want a stall with F/I?
M
mtbennett24
Got it. And the mild cam still gave noticeable results even without F/I? Thank you.
bleachii
