Catch can flow discussion
First off, this is more of a universal discussion and not exclusive to the '07-'14. I couldn't decide where else would be appropriate so I just picked the GMT900 forum. Mods, feel free to move it if there's a better place for it.
I have an average Amazon catch can slated for installation on a friend's Tahoe. I'll be modding it, making a mounting bracket and getting the hoses made up so it'll be a quick install on his. I'll use my '08 as a template since his Tahoe is an '09. In the process, I'll take pics to use in a how-to for these these- mounting, connecting, modding, etc.
In checking over this catch can, I noticed the "IN" and "OUT" ports seem to be opposite of the way my $100 catchcans.com can is oriented. With that one, the dirty air comes in and goes straight into the filters, baffles, etc. The filters drip the oil into the can's reservoir and the scrubbed air then exits the can through an unrestricted port. In the Amazon one, the inlet is the unrestricted port that feeds the reservoir then the air travels through the baffle, filtration media, etc. before exiting.
This is the can off Amazon, representative of most any other one:
If connected per the labels, the oily air comes in through that port with the small metal flap and fills the reservoir. The flow continues up through the baffle then the bronze filter then out of the can and on towards the intake manifold. Picturing the direction of air flow, the oil droplets collecting on the filter would have to drip against the direction of flow.
Referencing the catch can in my sig pic, from catchcans.com, the dirty air from the valve cover enters into the top center where it immediately hits one of a few stages of filtration then continues into the reservoir then up through the port in the side to go to the intake manifold.
Really, it seems they'd work fine either way. But one of the two ways has to be better than the other for some reason. This is what I wanna discuss. I'll be adding a stainless steel scouring pad to it for extra filtration media. But that's irrelevant in this convo.
My thoughts: These things work by coalescing. Hitting the filter first to stall the air so the oil droplets can collide and coalesce makes sense to me. The engine's suction will pull the oil through the filter. The oil slowly making its way through will (eventually) drip down into the reservoir as the air that gets through the filtration media more easily continues on through the unrestricted port. I read where some people said that this would keep the oil in hose coming from the engine. My response to that is "And?" The oil was in the engine in the first place, why wouldn't you want it to stay? It's not gonna fill the hose and plug off the flow of PCV. If it went into the can then was filtered on the way out, I guess the filtering effectiveness would be about the same. But, the reservoir might get more oil in it, which is that much more oil removed from the engine rather than remaining in it, under the valve cover where it can drain back into the crankcase.
After spelling out my thoughts here, I'm now thinking that either way would be fine for scrubbing the air. But if you need to actually remove stuff, like moisture, you'd hook it up as the ports are labeled. If you just wanna scrub the air to get the oil out of it, you'd hook it up in reverse. I've never drained anything but a few ounces of oil from mine. No milkshake (no moisture). So, I'd wanna keep as much inside the engine as possible. If my thoughts are correct, then I can leave mine hooked up as it is and I'll set up my friend's can in the same "backwards" direction of flow.
Your turn.
St. Louis
My thoughts is that gravity helps the oil drop out of suspension once the air has entered a larger space and changes direction. Baffles help by making the air change direction, like in a muffler, and causing the oil to stick to the baffle. Also in the same line of thinking with gas lines in your home and how they have a down leg on verticle runs for any debris that may get into the line to drop out.
I always thought our Catchcans.com one should have the input on the side port and exit through the top port. One of the reasons is that if oil in the can gets full enough up close to that side port that is sucking to the intake, any bumps or jostle of the can could easily let oil splash up to that port and suck oil in. Also, usually the suction port on any of these cans I've looked at are usually at the top and/or have a filter or screen before it. Thinking to keep oil from getting to it and sucked into the intake.
The cheap ebay can I had on previously for 4 years had both ports on the side, one about an inch below the other. The bottom port was the in and top port was out.
I have a breather type can on the blown mustang, but also run a mechanical vacuum pump. The discharge from the pump goes into the side of the can. Inside the can between the side port and the top opening are 2 or 3 staggered metal tabs that are the baffles and a small air filter is at the top. It does not return to the intake. The air hits a baffle plate and turns 90* to get around it. Oil catches on the plate and drops down into the can.
When I first installed the catchcans.com one like yours last year I hooked it up with side port in/top port out. Worked fine. After talking to you and also sending an email to catchcans.com asking correct orientation, both telling me top in, side out, I switched it. Works fine also, lol.
donjetman
I have a $130 Mike Norris Motorsports catch can on my C5 Corvette. Inlet on top, outlet on side. It doesn't catch liquid any better than the $30 side inlet and outlet chicom cc that's been on the Yukon for 5 yrs.
George B
¯\_(ツ)_/¯
Oconomowoc, Wisconsin 53066
Some old reading from a while ago.
Mounted the catch can today but need some 90° or 45° Hose fittings. I also need someone to confirm my thinking on the flow. The catch can has a port that goes straight into the body of the can and one with a filter on it. I assume the filtered port should be out to the manifold and the unfiltered one is in from the valve cover.
As required. :deal:
The inlet is the filtered side. Unless they flipped the design, the inlet should be the port on the left, if facing the top with both ports aimed away from you.
So out the valve cover and into the catch can port with the filter. Then out the port without the filter to the intake. If so mine is opposite the orientation you described.
Installed. I hope the flow is right. It comes out of the valve cover and into the port with the brass filter. Then out the unfiltered port and into the intake. I have some 45° elbows on the way because I don’t like the way the hoses come up to the can.
View attachment 275995 View attachment 275996
They must've flipped the inlet and outlets. I remember it being the other way around because it makes the hoses cross as they're routed from the cover and to the intake manifold. I considered getting the 3-port (dual inlet) version and plugging the other side just so the hoses didn't cross and looked neater. But, it's my bro's truck and he couldn't care less. All resolved with a simple hood slam.
St. Louis
My thinking on those models with the round brass filter covering the port, that port should be the exit back to the intake. If it was the input from the valve cover the oil will catch on that brass filter on the input side of it. Will it get sucked/seep through to the can side of the filter, yes eventually but may cause a restriction to the air going into the can
I have the JLT 3.0 oil catch can installed on my 07 Yukon XL Denali, and here is an excerpt from their web site:
"A filter on the inlet side of the oil catch can traps fine oil vapors and releases them once heavy enough to fall. By the time the oil gets through the filter it's too heavy to be passed on into the intake.
The tank holds 3 oz of fluid, while that may not sound like a lot, you shouldn’t see that much oil in your PCV system. Drain it every 2000-2500 miles on most applications and you will never come close to filling it. Average collection for most applications is roughly an ounce every 1000 miles."
You can see the inside of this catch can with an explanation of its function in the following YouTube video as the 2:45 minute mark:
George B
¯\_(ツ)_/¯
I swear the video says opposite what the text you quoted says. I think they mean the inlet port of the can not the intake of the engine. According to this the guy in the vid has it backwards.
Charlie207
LFOD, New Hampshire
I installed this cheap amazon chicom catch can 5 yrs ago. I added pot scrubber matl and drain valve. Its still working good today.
I have the same one as you, and I haven't had any oil/water collected in the last 2 oil changes I've done. I pulled it apart, and it wasn't the ball-valve seized. It was just empty.
When I first installed it, I'd get water/sludge in there. I wonder if it's something that's a non-issue in the warm months, but will return during the cold winter weather.
Edit: the bracket is straight garbage, but I've been too lazy to improve it.
St. Louis
And that silver mesh filter that is in that can looks exactly like the mesh filters that would go under the PCV valve on the lower intake on a Ford 302 engine and would help keep oil from getting sucked up through the PCV valve/hose
The Mustang PCV (positive crankcase ventilation) Filter Screen is a metal casing that is stuffed with a steel mesh type material. Its job is to trap oil vapor while the engine is running and keep it from collecting on the PCV valve or intake manifold. Once the Engine is shut off and cool again. The Vapor turns back into a liquid state and drains back into the lifter valley. Over time, however, these filters get clogged up and no longer allow proper ventilation. These are normally replaced when replacing the Pressure Control Valve (PCV).
fedwards
