Change the color of your 00-02 Tahoe/Yukon AC control backlights with LEDs
lowpost99
Lowpost99
Atlanta, GA
No, I have not successfully been able to remove the blue from the AC panel, or any other switches that have it. I HAVE however learned how to remove the bluish film from the instrument cluster overlay.
Hope you're still around my man. One or more bulb pads along with some of the circuit traces have lifted from the circuit board. I switched from a medium to needle solder tip, and still no luck, my solder sucker or my solder wick pulled them up. Do you have any suggestions on repairing circuit traces on PCBs?
alaska_guy
Alaska
You can run jumper wires using some copper wires. Not exactly sure what you have going on, but just use some solder and a copper wire and jump it over to the good trace.
lilb
