Mean_Green
- Joined
- Mar 23, 2023
- Posts
- 390
- Reaction score
- 523
I've been blathering about the clearcoat issues and haven't got much response.
I will NOT be doing a full repaint. Out of the question entirely. I'm not super fussy about exterior appearance, but the clearcoat is annoying.
This is 20 minutes with some 1500 grit wet or dry, some buffing compound and a little elbow grease. I haven't sprayed any topcoat on this spot, just wet sanded and rubbed. Yes, you can still see the defects and it needs more work. But I wanted to see if I could do anything at all before buying a sander/buffer to do a larger area.
I'll have to pull the brake light, but I'll be working around the luggage rack trim. Once I see what happens here, I'll try the larger areas of the roof in front of the rack. Then I might see about the hood, which is the spot I see most.
