Clunking noise after some gravel roads?
iboughtatahoe23
iboughtatahoe23
Yes, the front driver side is the one that looks the most suspicious. Your tire changing jack on just the driver front would be sufficient . Just trying to get some load off the link. Then do the same on the passenger side. If one is bad, you’re replacing both of them. They are pretty inexpensive. Actually, I would recommend you just plan on replacing them anyways because if they are not broken, they are well on their way.
My dad swears that that is what my clunking noise is that is happening random and intermittently. He says I don’t need a jack and I should be able to use an angle grinder with a cutting wheel to just cut them out and then put the new ones and he said it’s a five minute job each side.
wjburken
Eastern Iowa
He’s not wrong.
iboughtatahoe23
iboughtatahoe23
@wjburken and it’s not the tire changing jack for my Tahoe. It’s for my 2010 focus but ya I have two of em
wjburken
Eastern Iowa
Where can I place the Jack to lift the whole front end? Cross member?
You don’t need to jack the entire front end up. Definitely not if you don’t have good jack stands or a proper floor jack.
However, I have lifted on the front cross member when I’ve had the appropriate equipment.
iboughtatahoe23
iboughtatahoe23
This all seems like a lot I think I’m just gonna take it to the shop. I don’t even have all the proper stuff to do this.
wjburken
Eastern Iowa
Seriously, take the money you would pay for labor at the shop and buy some tools. Borrow the rest and start building up your arsenal. You can even find good deals on used stuff on Facebook market place
The sway bar links are $15.00 a piece so $30 in parts and some borrowed tools and some time, you’ll be back in business. Or you can spend $150 at a shop and still not have tools for the next thing that needs fixed.
Trust me, when you’re short on cash, you need to get better at doing things yourself. I fixed a lot of stuff with garage sale tools when I was younger. Still have most of them or have passed them down to my kids.
maxandpj
