Confused about Z71 OEM ft. struts
BlackBrud
Colorado
OP did you ever solve this? I believe z71 trims came with Rancho struts up front, but I'm a newbie to the forum so I'm still learning...
D
dbell54
I decided to go with the SR4079 KYB complete struts. There is NO prebuilt unit that is specific to Z71, but KYB cust serv insisted that this would perform correctly. If I wanted to build my own, I would have gone with the Bilstein 4600s, but I believe these will do the job (when I get around to installing them.)
BlackBrud
Colorado
Thanks for the info! I've been looking at replacing my stock front struts with the Rancho quicklifts, but I haven't been able to confirm how much they would lift the front since it seems like the z71s were already sitting higher than other trims when stock. I'll report back if/when I find more info.
D
dbell54
That was my concern, that the Z71 spring was taller. Guess I'll find out when I get these on. If it sits lower, KYB will have some 'splainin' to do.
blackelky
I just put z71 rear springs in maybe like .5 inch higher. And that's a strong maybe
Kaptainkhaos58
