Diesel and city driving?
Holy Roller
As already mentioned, diesels work best when run all day. Particularly on the highway.
But diesels can be used as grocery getters and mommy mobiles as long as your usage falls within the following suggested guidelines:
Diesels should never be started and stopped with less than 60 seconds running time. If you need to marshal your vehicle fleet around your driveway then a diesel is not a good fit for you.
A short trip would be defined as engine running 1-10 minutes.
A medium trip is engine running 11-29 minutes.
A long trip is engine running 30 or more minutes.
For every six short trips a diesel needs one long trip.
For every ten medium trips a diesel needs one long trip.
Most people’s driving patterns fall within these parameters. But not everyone.
Source: More than eight years driving Chevrolet’s 2.0L diesel.
C
chevyorcaddy
Makes me wonder… why auto start stop on a diesel? I’ve always thought it was tough on a gas engine to constantly cycle like that but seems like an even worse idea for a diesel
CTown Duramax
I think of marine diesels being left to run through cold weather spells, but this seems to be different technology. As others point out, these modern small displacement turbo diesels are in common daily use in Europe, about half the automotive market. Those diesels, anywhere from about one to three liters' displacement, run in everything from taxis, delivery vans, tiny econobox cars to big luxo sleds like S class L, 7 series stretch BMW's. They do just fine and are considered more durable and reliable than gas, worth the extra money.
It seems that the Duramax has a system of lubricating the bearings of the turbo charger fan after the engine is turned off. I have noticed after giving it a chance for a week that the auto stop start seems to learn my routes and now only shuts off for longer stops.
I would like to know more about the advances in turbo charging, materials and electronics that make these newer high output engines run so well.
R32driver
Just take it for a decent drive once in a while and it would probably be fine. We had a 2015 golf sportwagen tdi for a couple years and it usually just saw short trips here and there and it was all good. The only weird thing is when a regen was in process and it was being parked and that damn car was hot to the touch up front and smelled like it was going to burn to the ground. Other than that it was a great car. Babymax is probably the same kind of scenario but I have a 5.3 so pure speculation on my part
Stbentoak
I'm sure there are owners across the country that use them in all different ways. The real barometer of this issue is if it IS an issue. I can't say I've seen on this or any other Dmax forums that anyone has been getting "Keep driving" type of regen notices indicating a plugging DPF on LM2's because of short trips. I had an Eco Diesel that used to display them, and we just drove around till it went out. 10-15 min max. Didn't come back for a month etc. even if short tripping it.
I've done a fair amt of short trips in mine and not a whimper out of it. It does get a 75-mile, 80 MPH blast at least 1-2 times a month, which I'm sure certainly helps.
But I agree with others that this engine doesn't produce near the soot as HD engines, and I believe the 6 cyl Diesel was designed more with daily life in mind and not HD working truck needs and scenarios. Unless I never did ANYTHING other than short shuttle trips, I'd get the Dmax. But this vehicle engine combo really is meant to be a family road trip hauler and meeting the needs of the Dmax is zero issue then.
JEP25
Hi All,
Considering either the Yukon or Escalade with the 3.0L Duramax (have deposits on both :) ) This would be my first diesel, and I’ve heard mixed opinions on owning a diesel with intermittent driving habits.
Essentially in our new Covid work from home life, 80% of the time we average only a few miles per week, say 50-100 max. The other 20% of the time we’re hauling our family of 5 (dog included) either 10 hours north or south to visit family.
I’ve read in some of the forums that some seem to be concerned with the diesel and the DEF/emissions systems when it’s not driven consistently. Anyone out there have details or know whether this could be an issue for us with our driving habits on the diesel powertrain?
Thanks!!
I have over 14K on my GMC Yukon 3.0L. The fuel mileage for this pig is amazing, 28 hwy and 22 avg the rest of the time. I absolutely love this truck (engine, I wouldn't have purchased it if it was gas). It's also less money than the gas engine by about $1,600. I wouldn't overthink this, if you can get one, enjoy it.
jqwiii00
Hi All,
Thanks!!
We have had multiple diesel vehicles, both GM and Jeep. The regen process is not frequent and simply requires you to drive 15 minutes +/- while it happens. I’ve never heard any noise or noticed any difference from normal driving. It’s really no biggie. I live both out Jeep Grand Cherokee diesel and my Duramax 2500HD… especially the range. Both are good for about 700 miles if I’m not towing a load.
nfarios
Great read! Thank you everyone for your inputs on driving habits with a diesel. I am on the verge of getting my Tahoe RST delivered. Last I was told by Chevy customer service was that it was under quality review. This being my first diesel I did some research and found a useful device that shows when the vehicle goes through regen. (
) I’m not trying to promote the device, but I believe that the ability to visually verify when it goes in to regen is useful.
CTown Duramax
You'll be able to tell when the Duramax is in regen if you're looking out for it. The idle will be a little faster and there will be a deeper tone to the exhaust. Sometimes there's a slight melted crayon smell.
This engine is really good as it is. IMHO, run it for a few months before wiring anything to it, thinking less is more.
sqd pkl
Hi All,
Thanks!!
I am a diesel mechanic for a living and you have nothing to worry about. When the DPF first hit the market it was completely different than now. The engine can now do regens at low speeds or sitting still. DEF system has nothing to do with regen. DEF is mostly used at low speeds or idle to reduce Co2. You can also use Lucus Deep Cleen DPF clean now and then. Works very well! i use it in my dodge 5500 about every 3 tank because i idle ALOT! 132k miles and no DPF issues. I have more idle hours on the truck then drive hours. Think about all these 5500 series trucks that have PTO's on them to turn a hydraulic pumps say for a bucket truck. a lot of idle time and no issues.
Monster Nali
