Alberta Tahoe
- Joined
- Apr 25, 2015
- Posts
- 160
- Reaction score
- 33
I had posted in a couple of threads regarding an intermittent short/open circuit on my 06 Tahoe.
http://www.tahoeyukonforum.com/threads/intense-electrical-issue.92892/page-2#post-1113447
http://www.tahoeyukonforum.com/threads/heres-a-weird-one.89340/page-5#post-1113443
Bumps in the road would cause a momentary disconnect of the dash instruments, the power door locks would open/close and in a worse case, the vehicle would drop into a reduced power mode.
An inspection of the usual suspects (battery connections, major ground points, etc) didn't show anything that I would think would cause this problem.
Now, I'll have to get into this on a whole other level as the condition has become worse.
The intermittent connection now appears to be permanent. After being away for two weeks and the truck parked, attempting to start it resulted in nothing. As if the battery was disconnected. Then the gauge function returned (with no fiddling on my part) although all indicators were at zero (as in the fuel gauge showed empty despite there being 3/4 of a tank). This is with the key in the run position. Attempting to start did nothing. Further to that, removing the key made no change whatsoever! The data centre was still active and the dash idiot lights remained on despite the key being pulled from the ignition switch.
To me , this points to the ignition switch as being the culprit but short of doing a re and re, I have no way to determine if that's the case.
Has anyone had a similar experience?
The chassis grounds are one thing and I understand how any one of them can cause a problem but a chassis ground isn't going to create this latest condition. This is more like a meltdown or failure of some component entirely.
It's far easier to ask here and go on other's experiences and repairs than it is to start taking things apart with no direction.
Thanks in advance.
Thanks in advance.
