Electrical Issues - Speedo, Traction Control, Stabilitrack, DIC Flashing
jrobie79
Any ideas what would cause this? 2012 Escalade Platinum. Just started happening a few days ago. Before it starts tweaking out I'll get the stabilitrack and traction control off message (that's why both are illuminated) as well as detection module failure.
I replaced the ground wire from the battery to the engine, and added one from that engine stud to the passenger strut tower/frame. Also replaced the small wire from the battery to the bolt behind the bumper.
ls1frc
I had something similar
Replacing all the battery wires fixed my issue. The positive to the alternator, the positive to the starter, and the negative cable. I bought factory GM new parts, cost about $200.
J
jrobie79
I replaced the battery ground and the ground braid at the firewall so far. The positive cables are next
petethepug
Michael
SoCal
Yes Sir, there’s definitely some contamination in your electrical system. I’ll finish this 21 point diagnostic here and may have to replace the battery cables with OEM Cadillac cables special ordered from headquarters in Michigan, or was that Mexico?
I’ll keep it under $1,500.00 for you.
SWoolf777
