Hard Trany shifts. Q’s for the pros
Dirty30
Hello 1st post here. Came to seek some info on my transmission and ask for advice. My 16 Yukon XL has been shifting hard from 1-2 & 2-1, and sometimes feels like it’s slow to engage and start rolling in 1st, revs a lil and jumps into gear if you don’t give it a sec to engage. Took to dealer & said I needed a whole new trans ($6k) That was almost a year ago. So my question was, if this is a common problem and “just replace this part/that part” or if I need a full replacement or rebuild? Also if so does anyone recommend a certain company or parts to use? I’m thinking I will be buying a new Yukon for family and keeping this for back up or trade this in for the new rig. I’ve had valves replaced and AMF deleted. So with a new tranny do you think it’s smart to keep around or are there other issues know to come up around that 150k mark?
Thank you for any help or insight.
2016 Yukon XL Denali; 128k I have owned since 20k and has been wife’s car and family road trips, no towing, no racing, have replaced trany oil 2-3 times with the last time being the recommended Mobile 1.
donjetman
U posted in the 2007-2014 area?
Welcome to the Forum from NH.
Pics of the truck, please.
@NickTransmissions is our resident transmission expert, and he will chime in with his thoughts and perspective.
NickTransmissions
Sin City
The transmission bench
Sounds like either your rear sprag is starting to roll over or 1-2-3-4 piston is cracking...Could also be valve body, pump (worn PR valve), TEHCM and/or torque converter (the TCC is active in gears 2-6 and may not be releasing properly upon the 2-1 downshift).
It will need a full diag work up starting with a test drive w/bi-directional scan tool plugged in to confirm the drivability symptoms as being caused by the trans (Dealer likely already did this, hence their diagnosis) then trans will have to come out, valve body and TEHCM bench tested, TC cut open and trans torn down and inspected.
I can't speak to other, non-transmission related issues other than AFM/DOD, cam bearing and lifter failure are somewhat common for LSX engines north of 175k so if you plan on keeping it for the long haul, I'd do some engine testing/diagnosis to determine if you'll soon need major work there as well before committing to the transmission job.
Dirty30
Dirty30
No worries. Fixed.
Thank you.
Does anyone one know of a company that sells remans with upgraded weak points for these trans? I read that GM replacements don’t address the weak points with their replacements? My Transmission shops near me are very limited so I feel I might try and do it myself as long as I’m not tearing into the insides on the tranny. Replace TC and trans at same time?
Anyone heard of Go-Powertrain? Free shipping and core returns!
NickTransmissions
Sin City
Thank you.
Anyone heard of Go-Powertrain? Free shipping and core reruns!
Why are you hesitant to rebuild the transmission?
Per your drivablility symptoms, it's a least 50/50 you'll need to get into the case and overhaul it.
Never heard of Go-powertrain. Post a link to one of their 8L90 remans and ill take a look, give my thoughts.
Dirty30
Dirty30
Never heard of Go-powertrain. Post a link to one of their 6L80 remans and ill take a look, give my thoughts.
Reason I’m hesitant, is I guess I’ve never been involved in digging into one and wouldn’t know what I’m looking for. I’ve done a decent amount of backyard mechanic work just nothing with trans.
Leno1364
