Heater not blowing any heat
travo87
OK so the other day my cousin took my radio out of my truck to get my audio wires out to use well ever since then and I don't know why but since then my heater doesn't work no heat no lights on the knobs and no actuators working only thing that works is the blow motor everything is hooked up on the control unit all heater hoses are connected no leaks nothing looks as if it's bad I'm so confused on this cause where I live it's 7 in the morning and it's 10 degrees it takes along time to defrost my truck without heat any ideas
Hoesgottaeat2
Western NY
Have a read here. Sounds like some parallels to what you're experiencing...
OK so the other day my cousin took my radio out of my truck to get my audio wires out to use well ever since then and I don't know why but since then my heater doesn't work ...any ideas
Any update on this? Do you have an IPhone and an OBDII adapter? If so, you can download CarScanner app onto your phone and pull up the internal BCM codes.
first thing to do is check your fuses, especially if the battery was not disconnected while your "cousin" was messing with your ride.
travo87
travo87
Yes heater is fixed unplugged wire hidden wire couldn't see until I took the hvac control oit the truck
ChuckWoodChuck
