Hellwig Sway Bars Installation - 2007 Yukon XL Denali
Sparksalot
Bastrop County, Texas
Perhaps, it is because you've had GM vehicles for a while (if that is that you've used the 18mm tool on many times). This is the first GM product that I've owned or worked on since the late 1960's, and they weren't metric back then.
I’ve had to get some 18mm as well. It used to be metric was always odd in larger sizes.
91RS
GA
I had the Eibach bars on mine and then changed to the Hellwig and I couldn't believe how big of a difference it was considering I already had bigger bars installed.
I didn't need the spacers on mine. I ordered it not knowing I needed them and found out after it arrived. I tried it anyway and the bar is nowhere near the transmission lines. Mine also came with new bolts for the front straps so I'm surprised you had to reuse the originals.
ACPTECHS
