Help swapped engine and now it won’t turn over
Cocobug1999
I recently purchased an 04 Tahoe with 198k miles. Truck had been sitting for a couple months. I put a hot battery in it and it fired up. The oil was sludgy so I changed it a couple times hoping it would be okay well cylinder number 3 rod bearing spun. So I bought a used motor that ran to replace it with. Freshened up the new motor and installed it and now the vehicle has a no crank issue. All the lights come on and it has power but will not spin over. Starter relay clicks but starter will not engage. Please help!?!
nonickatall
Germany
Did you mount all mass points and connectors properly?
check everything again...
C
Cocobug1999
Yes. I went over the whole motor all the grounds. I forgot a wire ate first on the ground under the ps pump. Cleaned the block and bolted both back up. When I attempt to crank it the dash lights dim and then come back on when I let off the key
nonickatall
Germany
Did you use your starter or is it from the swapped maschine? Have you tried cranking the engine at the front flywheel to check whether the engine rotates freely?
Joerob25
