Highlighted posts from Monday, May. 17, 2021
TYFBot
Click here to view on the web
Highlighted posts
May 16, 2021 * 23 posts * 534 views
Rdr854 said: I stopped by a GMC dealer in Northern Virginia to look at a Yukon XL. The dealer only had Denalis and one AT4. While I understand that there is a shortage of new cars, I thought ... Read more >>
May 15, 2021 * 21 posts * 352 views
swathdiver said: A week or two ago, while we were removing the wheel well liners, we noticed that the #4 spark plug was loose. The wire and shield were bouncing around and exhaust gases were coming ... Read more >>
May 14, 2021 * 19 posts * 382 views
McLeod Crouch said: Yeah so found these in the oil pan.. any ideas? truck was running fine. The brownish parts are plastic it feels like. The others are metal i believe. [image] Read more >>
May 14, 2021 * 17 posts * 292 views
newtek007 said: 2006 Chevy Tahoe LS 5.3 engine Sooo.... been dealing with multiple transmission rebuilds since last June. Truck has 242,109 on it right now. Tranny last year started to go bad ... Read more >>
May 15, 2021 * 16 posts * 222 views
kbuskill said: I am planning on retrofitting these headlights and am trying to decide what I want to do to the inside of them to make them a little different. [image] I will only be installing ... Read more >>
May 13, 2021 * 19 posts * 266 views
Tonyrodz said: I have the manual hvac headunit with the temp sliders. Does anyone know if there's a reset procedure? I bought a Dorman replacement--which initially worked, but now everything ... Read more >>
May 14, 2021 * 23 posts * 245 views
Shtiv said: I replaced my air ride compressor because i thought it was louder than it should be (the sound was normal but didn't know that due to the Yukon being new to me), so the new compressor ... Read more >>
May 16, 2021 * 11 posts * 150 views
Kwing said: I can't make this crap up. I am currently on my 4th set of motor mounts in 40,000 miles on my '07 Tahoe with the 5.3 FFV. First set went out just before 200k. Went to turn hard ... Read more >>
May 15, 2021 * 17 posts * 113 views
tRidiot said: So the portion of my driver's and passenger door panels that hold the window switch have broken clips inside, I need to replace them. Here is the part I am talking about, in the ... Read more >>
May 13, 2021 * 15 posts * 264 views
Joseph Garcia said: After considering the various recommendations from you knowledgeable folks here in the Forum, I am going to convert back to the original Z55 air suspension on my 07 Yukon XL Denali. ... Read more >>
Continue reading...
Dano1
