How To: Borla 140193 complete exhaust upgrade
CHOO CHOO
BackPagePhil
Manheim, Pa
So I put in my exhaust today and heres a little how to for everyone who might need it. Please feel free to add if I missed anything and let me know how I did!
List of tools needed:
3/8 wrench
3" extension or larger
15mm deep socket
Jack stands or something comparable
Some type of jack
WD40 or grease
Muffler stand or a helper
Reciprocating saw or something similar
Put on your e-brake please and raise your vehicle.
Unscrew the two screws pictured here. They were on a little tight for me so I used a torch to heat them up and loosen them. Be careful as one of mine busted completely off.
Place the muffler stand in place. Then loosen all of the barbs that hold the muffler and pipe in place. There should be 5. I used the WD40 on them and it helped a lot in getting them off. They look like this:
Once you get that done, use the reciprocating saw and cut the pipe so you can remove the complete system. I cut mine right before the resonator, but do whatever works for you.
Then take the new pipe and screw the two bolts back on:
Now I had to lower the spare tire in order to get the pipe in place. Once I did that I took the bent pipe with the tips and took the barbs and secured them back in the rubber grommets.
I then took the clamps that came with the kit and put them on the pipes first. Then I put the muffler on.
Tighten the clamps. Don't tighten them too tight otherwise the pipe might oval and create leaks. Go back and check everything and make sure it is secure and the bolts are tightened. Put the spare tire back in place.
Here is the final outcome, from this:
To this:
Now like I said, this was just they way I did things and you may need to do things differently depending on your situation.
I hope this helps anyone who might need it and let me know how I did!
---------- Post added at 10:19 PM ---------- Previous post was at 10:18 PM ----------
I will adjust the size of the pics just give me a few.
Tahoewhat
Ballin' on a Budget
TX
Very nice instructions w/ pics, which help 100x better than words.
THE YETI
Director of Operations
South FL
Looks really good! Love the tips!
Administrator
Nicely done!!
CHOO CHOO
CHOO CHOO
BackPagePhil
Manheim, Pa
Heres the real question. What the hell do I do about the broken off bolt....fml...
Do I really have to replace that pipe?
This may sound dumb bout how do I upload the videos of the sound? Is there a website? I use imgur for the pics but not sure about videos.
jd08
Jackson, WI
Can you drill out the bolt on the flange and then just use a regular bolt on that side?
CHOO CHOO
CHOO CHOO
BackPagePhil
Manheim, Pa
Burb, is it possible to make this a stickie? I looked around for a general exhaust how-to and couldn't find one. Thats why i made this. Thanks everyone btw!
Sent from my DROID4 using Tapatalk
CHOO CHOO
CHOO CHOO
BackPagePhil
Manheim, Pa
Honestly, i dont really notice it. It is a little loud at lower speeds, but i havent driven past 55 mph yet so i dont know about highway. I feel like its quieter than my magnaflow which is nice. I will post up sound clips later today.
bl74
