How To: clean the EGR
fyremanpat
Fyremanpat
Here it is
and after pulling off, this is what 120k looks like
and a good amount of carbon build up
after cleaning with steel brush and carb cleaner
and after bolting it back on the idle was smooth as margarine...
I strongly agree to putting a new gasket in afterwards...
puckhead
CO
Maybe im slow, but im not seeing it in the first pic. could you point it out? I would like to do this as well
fyremanpat
fyremanpat
Fyremanpat
dead center of the first pic. has a four wire harness, it cylindrical, above the coolant line
puckhead
CO
Sweet, thanks dude! should be easy enough to find
Miami-Yukon
'96 Z71 YUKON 2DR
Miami (305)
Well this could save me some money, I was just looking for a new one...
I found a couple on ebay, new for $98 shipped and another one for around $60...
But hey $60 or $98 is still money that I can do other things with....
I'm gonna try this, maybe this weekend when I do my rear brakes...
Thanks
TahoeJim
SE Ohio
just did this and it worked. mine wasn't that dirty though
Did mine today, out of boredom really! 89k miles, I used a dremel with a nylon brush mandrel and scrubbed out the inside of the housing then blasted it with brake cleaner.
Also did the IAC while I was under the hood. Started up and idled fine, but it wasn't lumpy or erratic before. I'll see how it does next trip into town....see if it feels any different.
99Yuk
Northern Ontario, Canada
I did mine today as well as the IAC. I used Tahojim's dremel idea and intake cleaner to get inside the body and clean it out good. That's a really good idea, it works well!
You wouldn't believe the amount of black crud that comes out.
I havn't tried this stuff out on the highway yet today, but I'm anxious!
98chubby
Is it possible to block the egr? Also wouldn't it give you more power if one did? I only ask cause my friend did that to his truck and he cold feel it more in the accelaration.
BenK
