How to MarkVIII your OBS on a budget..!
oakdog
How much cfm do these fans pull? If you know.
Sent from my SAMSUNG-SGH-I747 using Tapatalk 4
oakdog
Not bad
---------- Post added at 05:39 PM ---------- Previous post was at 05:33 PM ----------
Monstar_est87 you were right about the mark VIII pulling 60 amps. I haven't had any problems but I am coming up with an alt controller.
saif najd
Looks good... How is it being controlled..?
By 3 relays this the modes:
1- both working full speed to cool it down
2- if no need to cool the the radiator but the A/C clutch kicked ON then single fan will work
3- if both are working and the A/C clutch kicked ON then one of them will work for the A/C and the other will continue for the coolant.
I figured it out soon it was done by the previous owner actually
---------- Post added at 07:34 PM ---------- Previous post was at 07:33 PM ----------
Sorry I don't know I wish I could
---------- Post added at 07:34 PM ---------- Previous post was at 07:34 PM ----------
I believe low is 3200 and high is 4600 cfms... Just off the top of my head...
It is on high all the time
---------- Post added at 07:35 PM ---------- Previous post was at 07:34 PM ----------
Not bad
Thank you
2drhoeon4s
if I knew about this i probably wouldnt have gone with Flexalite dual efans... $$$
Monstar_est87
Monstar_est87
City of Angeles
Not bad
Yea they can draw quite a bit so make sure u get a relay or relays that can take it... And a self resetting fuse aka circuit breaker...
Its all good... Ur flexalite match ur sweet @ss truck...
By the way this one of the most famous mods locally for efan conversion
Good work saif najd... Electric tape and wire loom go a long way 2 protect ur wires and clean things up abit...
MC153
I remember you told me about this when I first got my Tahoe. Just barely found the thread. I wanna do this with a Jegs kit. I will get the fan for $14 from the junkyard. My only concern is the power draw. Will I need to upgrade my alternator? If I have to, this mod will have to wait for awhile.
retorq
Kingman AZ
I ran dual fans with the Jeg's kit for a while with the stock alternator. It's a good idea but you don't have too...
hotrodford
