I need help with 2002 z71 tahoe 5.3 4x4
wjburken
Eastern Iowa
I got some jacks and some cinder blocks lol
Basically, that’s what you need. If you have a set of jack stands, put those under the front and then put your jack under the rear axle. Better yet, if you can afford it, invest in another set of jack stands or see if a friend has a set you can borrow.
Just make sure that you are safe about and no one gets under, behind or in front of your vehicle while you are engaging the different positions of the transfer case.
rockola1971
Indiana (formerly IL)
Check transmission fluid level. Drain some Tcase fluid and look for glitter and check the magnet of the tranny and the Tcase for chunks. You will need to drop tranny pan to check the magnet.
