Stbentoak
- Joined
- Jul 20, 2020
- Posts
- 1,552
- Reaction score
- 1,692
I probably don’t understand how it works, but I only see 2 hose connections… does fluids flow thru the blocks with the studs in them also?
Yep, the studded ports are for tranny fluid (higher pressure hence the bolted connection) and the beaded pipe connections are for engine coolant.
Here’s a picture of it in action. It’s right above the front diff. driveshaft.
This works in conjunction with a cooler mounted in front of the radiator. In between the two coolers is a thermal bypass valve (second picture) I believe it works such that unless additional cooling is needed, tranny fluid does not flow to the cooler mounted on the radiator.
View attachment 390076View attachment 390077
Well sadly, it’s leaking again. Should I…My guess would be that worm clamp has loosened a bit (classic problem with screw drive clamps). Also, I would shift it to the left by about 1/4". Clamps should be installed just after the bead on the tube. It's a bummer that access to the screw is on the wrong side (mine is the same orientation). I would put a box end wrench on it, loosen, turn 180, shift closer to the bead and retighten.
Take it back. As long as you have warranty don't get your hands dirty.Well sadly, it’s leaking again. Should I…
Take it back?
Try to tighten clamp myself?
Try to put on a new or 2nd clamp?
If I remove this one to replace is there any fear of hose pushing off on its own? Any better clamp to use?
I would just take it back - GM has an issue going on here and needs to see warranty claims coming in for this assembly so they can examine/root cause/fix.Well sadly, it’s leaking again. Should I…
Take it back?
Have you seen this before or heard of this problem? They did replace the hose that goes from the filler to the tank but I don’t think they did a great job with clamps. They look like the cheapest hose clamps you could ever use. I’m about ready to buy some t bolt clamps and fix it myself but when I put my hand up on the steel part of the neck where the filler neck goes in, it’s wet with diesel. It could be wicking up there.I would just take it back - GM has an issue going on here and needs to see warranty claims coming in for this assembly so they can examine/root cause/fix.
What year? I'm having trouble locating a fuel filler neck assembly for my 2000 Tahoe Z-71.Update, had To order a whole new fuel filler neck assembly. Of course, part isn’t available…. they say hopefully less than a week.
