bobsburban
- Joined
- Aug 19, 2020
- Posts
- 104
- Reaction score
- 184
Pardon, in advance, the mini-novel. And thanks everyone for the replies to my question regarding 1500 vs. 2500 frames and suspensions in this thread: https://www.tahoeyukonforum.com/threads/1500-vs-2500-frames.125382/
Been pondering those comments and what I'm looking to accomplish with this 2011 1500 that I have. Including the purchase price, the improvements noted in my signature, very robust preventative maintenance, and the tires, I'm all in at $14,800 or so for a truck with 240,000 miles on it. And where I'm headed is possibly a heavier trailer for full timing with a nod towards off-road, though no more so than NFS and BLM roads for the most part. Right now for a 3 week trip with a 17', 2900 lb Winnebago plus food & clothing, camp gear, 10 gallons of gas on a hitch shelf over the two 30 lb propane tanks, 10 gallons of water in the 'Burb, tools, fishing gear, cooler with drinks & ice, etc., etc. and I'm pushing 4000 - 4200 pounds in the trailer, another 700 in the 'Burb (including our weight), and about 500 lbs hitch weight. I'm installing Air-Lift bags after we get back from the UP (couldn't get them here in time to install before the trip) and am using a Husky WDH with the 800 - 1200 lb bars. From a handling standpoint, I don't know the trailer is back there but from a power standpoint, I'd like a bit more uumpf.
We're also talking about going full-time in a year or two and are considering a 23.5' Oliver or a used 25' Airstream, which are both in the 5000 - 5500 lb (dry) range as far as weight. Which puts us at 7500-ish total plus the truck's weight, which is starting to approach the 80% limit on the truck when using a WDH. So I'm curious about increasing the capacity of what I have, first, before exploring the increasingly pricey realm of 3/4 ton Suburbans.
To stick with this truck, I'm seriously considering going from my current 3.42 gears to 3.73s or 4.10s to help the 5.3 cope with our current weight and 32 - 33" tires. And while the 5.3 isn't showing any signs of distress, dropping in a 6.0 (especially if we go with a heavier TT) would also be likely, along with a wooden bed platform/storage box combo in the back of the truck (which adds sprung weight) so both grandkids could travel with us at times and have a place to sleep.
So, what are the real variables that determine towing capacity? Engine size? Cooling capacity? Gearing? Brake capacity? Frame strength? Can anything be traded off if others are improved? (For instance, the only reason a ZR-2 Colorado's towing capacity is 5000 lbs and the Z71's is 7500 lbs or so - with Duramax engines in both - is the bumper design which impacts the ZR-2's cooling.) And considering those variables, what would be your thoughts on a strategy of re-gearing, installing larger brakes, and/or installing another engine (if it were to blow or, hopefully more likely, we were to upsize our trailer) vs. looking for a 2500 in good condition? In this scenario, my total investment is going to probably go north of $22k. Maybe as much as $25k. (For comparison, the last Federal 2500s I saw on Chicago Motor's website were in the high-$20s to mid-$30s. At the moment there's only a 3500 HD on there right now - and it's a bit pricey at $60k.)
Thanks in advance for helping me plan for what's coming. Things seem to be quite a bit more complicated than when I was a kid helping dad pull a 30 foot Holiday Rambler through the west with a 4WD International Travelall.
