Loose second row seat lever
Tyrell
The lever on the second row driver side seat which allows it to slide forward and backward is loose on my '22 Yukon. Is this something I can address on my own or do I need to make the drive to the dealer? Thanks, all!
StephenPT
St. Helens, OR
Easy fix. Look closely at the round plug at the pivot point of the arm. There’s a flat spot on the plug for you to pry it out with a plastic trim tool. A plain end screwdriver will also work, but take it easy so you don’t dent the plastic.
Behind the plug is a T-20 torx head screw. Tighten the screw and reinstall the plug. Save the gas and time it would’ve required to take it to the dealer.
Jimbo123
Ha, thanks, will be doing this today as well.
ACPTECHS
