Lower thermostats, really needed?
STORMIN08
redline makes " water wetter " similar to purple ice, ect.
it is just a wetting agent,
DAmn BRain fart....cannot remember the terminology rite now.....
it does work, it will lower temps a few degrees, if one want a slightly lower
coolant temp with out the effects of a lower t stat, this would be a happy medium.
JennaBear
JennaBear
Resident Ninja
Supporting Vendor
San Diego, CA
Ah ok, yes I have heard of water wetter. I think Justin has used it on our vehicles in the past.
DennisW1
Question: what do you think about this product called "Red Line"? Does it rally works in V8 engines. I have previously own 4 and 6 cylinder vehicles and I have seen good results.
Thanks.
I think you're refering to Red Line's "Water Wetter". It claims to help water transfer heat better. I've never used it so I cannot comment on whether it has any benefit or not
aflumb
Las Vegas
I used it on my WRX as the turbo is water cooled. It works great. But it's not meant to be used in cold climates. The reason is ur suppose to drain ur system and use just the water wetter and water only. No coolant. So u will run the risk of freezing hour system . But it does drip the temps
Sent from my SAMSUNG-SGH-I337 using Tapatalk
livingez_123
Sandy, OR
Thanks.
Water Wetter by Red line. I used in my track car, and it did wonders. I tried in my Cummins diesel and didn't see any results that would make me buy it again.
If you want the best cooling you can get, ditch water all together and use Evans coolent. make sure you flush the system first with Evans Pre Flush.
it only runs about $42 a gallon.
02gmcdenali
The exceptions to this would be the 8.1L and the 2500HD 6.0L that do heavy towing; they have design flaws.
What exactly do you mean by design flaws? The 8.1 is a Gen VI big-block and the 6.0 in the 2500hd is the same 6.0 that's in the denali yukons. I personally have a 04 2500HD 6.0 and there isn't a design flaw present. Truck has never overheated no matter how hard I run it or when I have towed.
JennaBear
JennaBear
Resident Ninja
Supporting Vendor
San Diego, CA
I wouldn't say it is a design flaw so much as the setup does not take into account the high oil temperatures that arise as a result of heavy towing. Those high oil temperatures yield higher than expected oil vapor content, which results in a damaged MAF sensor more often than not. The vast majority of owners have no idea whatsoever that they have a very critical sensor that is reading 15-25% off.
tazjamin
Casa Grande, Az
what about the 6.2l in the denali, i just bought a 160 thermostat but now since i read this im holding off
