skpyle
- Joined
- May 15, 2021
- Posts
- 396
- Reaction score
- 1,028
Hello All,
As I can never leave well enough alone, I am planning the next project for my 2013 Escalade ESV AWD.
She has 153,6** on the clock. As of now, all seems good in the front end. However, sooner or later, it will not be.
I plan to preemptively rebuild the front end between now and 160,000 miles.
I have read through some posts here on TYF, lookin' at you @donjetman .
I have dug through GMPartsGiant.com and RockAuto.com.
I want to run my shopping list by you guys for a BS filter:
-both upper control arms with ball joints and bushings. Looking at the forged steel arms
-upper ball joint nuts
-both lower control arms with ball joints and bushings. Looking at the forged steel arms
-lower ball joint nuts
-mounting bolts and nuts for all the control arms
-caster/camber adjusting kit
-antisway bar stabilizer links
-antisway bar mounting bushings
-inner tie rod ends
-inner tie rod end boot kits
-outer tie rod ends
-both CV axles
-CV axle nuts
-both front wheel bearing hubs with ABS speed sensors
-mounting bolts for the wheel bearing hubs
-both front differential mounting brackets with bushings
-mounting bolts and nuts for the front differential mounting brackets
My plan is to go all GM, with the exception of the caster/camber kits. I will go Moog for them. GM only offers the cams, I want the whole kits.
So far, the only hiccup I am having is finding the correct part number for the upper ball joint nut. Service manual states to replace the upper and lower ball joint nuts upon removal.
-inner tie rod ends
-outer tie rod ends
-both CV axles
-CV axle nuts
