Hello everyone,
I am in need of some help.
I have a 2015 GMC Yukon SLT.
141,000 miles
About 2 weeks ago the climate control panel stopped working.
No power, no ability to change anything, nothing at all. Radio is fine, heated seats are fine, all other electrical seems fine.
The Yukon still blows heat at a low fan speed (I assume this is what the vehicle was set at before the panel went out)
1.) I initially checked all the fuses relating to the HVAC, all fine.
2.) I unplugged the battery for 10 mins
3.) I ordered a new panel (Part # 84412941 - https://www.gmpartsdirect.com/oem-parts/gm-dash-control-unit-84412941) installed it, nothing
4.) I finally took it to the Chevy dealership. They tested "eeevvverrrthhinnnggg" including modules, pin testing, etc. over the course of 3 days, and determined that the part I ordered was bad. The GM tech concluded that could be the only problem. They wanted $590.00 for parts and labor. Wouldn't guarantee a refund if that part didn't fix the issue. Picked up from dealership
5.) Ordered a NEW panel from a different site, installed, still nothing
I am so lost and confused.... PLEASE someone help.
Thank you.
141,000 miles
Thank you.
