mattbta
Hi, all.
8 years ago I had the one side hot the other cold with the A/C on, so I replaced driver blend door -- the one that you remove the hush panel and it's in front of the center console way back there. Ice cold on DS.
Now I have an odd problem. The passenger side doesn't blow nearly as cold NOR as forceful. It's not like it's blowing full hot - I need to get a thermometer on it but I'd guess maybe 10* warmer and not near as strong. Is this the temp actuator for passenger side -- the one under the duct that's hard to get to (some take dash all the way out)?
Also -- any ideas on part numbers? I've got the dual climate auto/electric controls with rear AC (CJ2, C36, C69). The driver one I replaced using a Dorman 604-106. Not sure If I should go Dorman again or Delco. I'm finding 15-72971 on Delco.
Thoughts?
EDIT: I've gone through the recalibration numerous times with no luck.
Thoughts?
