Polyurethane leaf spring bushings or not?
96-2D-Hoe
As removing the OEM bushing looks to be a real PIA it's probably a good idea to only do it once.
Seems it would be much easier to replace polyurethane in the future than have to remove the sleeve of an OEM bushing.
How do the polyurethane bushings hold up/ work out? Any good? Are you happy with them?
Thanks for any previous experience
TigerEyz3
Slow and Steady
TN
As Swathdiver said... polyurethane is known for squeaking. Lube well and you'll be fine (re-lube when squeaks occur).
fastpat
Upcountry South Carolina
Dusting off old memories, seems like there's a company that makes non-squeaking poly bushings that have graphite impregnation in the poly.
Then again, that may be old, out of date info.
Darryl251
